Reply on options messages
We are already connected to the operator, and they are sending SIP OPTIONS messages on a scheduled basis to verify that our system is up and running.
However, we noticed that Dialogic HMP 3.0 is ignoring these OPTIONS messages and does not send any response.
Could you please advise:
  • Is there a supported way in Dialogic HMP 3.0 to automatically respond to SIP OPTIONS messages?
  • Are there any configuration parameters or SIP stack settings that need to be enabled to allow replying to OPTIONS (e.g., 200 OK)?
Can you please post the VoiceGuide and WireShark traces capturing the system startup and the OPTIONS messages. We can then see what is happening on the system and advise.
VoiceGuide traces are in VoiceGuide's /log/ subdirectory.
SECURITY_NOTE: Please change the password used on the SIP account after posting any WireShark traces that capture SIP registrations or call authentications. Otherwise, if password is too simple, it can be cracked from the posted WireShark trace. If other parties crack your password then they may be able to start making calls through your account, which can result in large call charges on your SIP account.
